[GRASS-user] most recent kyngesburye build for osx tiger error
William Kyngesburye
woklist at kyngchaos.com
Thu Dec 18 22:00:31 EST 2008
On Dec 18, 2008, at 7:56 PM, Michael Barton wrote:
> 2) We just found a problem with a gdal framework (this might be your
> problem). The last version 1.5 at least is compiled with a
> PostgreSQL dependency. It needs to be recompiled without Postgres.
> I'm not sure about 1.6 but wouldn't be surprised if it is accidently
> the same.
Damn. Missed a bit of post-processing in the 1.5 build. 1.6 is OK.
If you have the Xcode tools installed, you can fix it with this in a
Terminal (all one line):
sudo install_name_tool -change /usr/local/pgsql/lib/libpq.5.dylib
@loader_path/Libraries/libpq.dylib /Library/Frameworks/GDAL.framework/
Versions/1.5/GDAL
I'll package up a new installer ASAP.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
