[GRASS-user] Re: Command to summarize the frequency distribution table
SGW00412 at nifty.com SGW00412 at nifty.com
Sun Dec 21 07:10:48 EST 2008
Dear Moritz and all
Thank you useful and kind advice.
Sorry, please give advice to me a little more.
I tried the re-classification by using r.reclass method in the raster map of the
probability distribution.
An initial probability distribution is as follows:
|MAP: (untitled) (maxent_v2 in PERMANENT)                                     |
|                   Category Information            |  cell|  square     |
|                #|description                          | count|kilometers|
|         0-0.003801|from  to . . . . . . . . .. . . . . . . | 25890| 52,649.00|
|0.003801-0.007602|from  to . . . . . . . . . .. . . . . . |  4738|   9625.82|
|0.954007-0.957808|from  to . . . . . . . . . . . . . . . . |     1|      1.97|
| 0.965409-0.96921|from  to . . . . . . . . . . . . . . . . |     1|      1.94 |
|                *|no data. . . . . . . . . . . . .. . . . . |134527|272,251.90|
I want to classify it at 0.1 intervals. So I wrote text files as follows:
0.0 thru 0.1=0 A
0.1 thru 0.2=2 B
0.3 thru 0.4=3 C
0.4 thru 0.5=4 D
0.9 thru 1.0=10 J
end
then, I saved as probability_class.txt
r.reclass input=old_rast_map output=new_rast_map < probability_class.txt
then,  following massage printed out on display:
0.500000 rounded up to 0
0.600000 rounded up to 0
1.400000 rounded up to 1
1.500000 rounded up to 1
|MAP: Reclass of maxent_v2 in PERMANENT (re_maxent in PERMANENT)              |
| 5| . . . . . . . . . . . . . . . . . . . . . . . . . . . .| 39215| 79,669.75|
|10| . . . . . . . . . . . . . . . . . . . . . . . . . . . .|   698|   1397.98|
| *|no data. . . . . . . . . . . . . . . . . . . . . . . . .|134527|272,251.90|
Why ? What's happened ?
I do not understand the cause not appropriately classified.
Best regard:
Yasuo shimada
Moritz Lennert <mlennert at club.worldonline.be>‚³‚ñF
> On 16/12/08 14:40, SGW00412 at nifty.com wrote:
> > Dear Moritz:
> > I wish to express my gratitude for your valuable advice. Thank you.
> > It succeeded when having tried as follows:
> > 0 thru 100=1 0-100m
> > 100 thru 200=2 100-200m
> > 200 thru 300=3 200-300m
> > 300 thru 400=4 300-400m
> > end
> > save as alt_class.txt
> > r.reclass input=old_rast_map output=new_rast_map < alt_class.txt
> > r.stats new_rast_map -c
> Note that you could have also done something similar with
> r.report map=old_rast_map units=k nsteps=
> playing around with nsteps to get the same ranges. But r.reclass +
> r.stats/r.report gives you more precise control of your classes.
> Moritz
