[GRASS-user] Error with v.rast.stats
Markus Neteler neteler at osgeo.org
Mon Dec 22 09:30:23 EST 2008
On Mon, Dec 22, 2008 at 3:07 PM, Agustin Lobo <aloboaleu at gmail.com> wrote:
> Hi!
> I run v.rast.stats and get the following error:
> alobo at alobo-laptop:~$ v.rast.stats vector=SAmDiv3 raster=SAndvi199201d
> colprefix="ndvi199201"
> GRASS_INFO_WARNING(18452,1): This module has been replaced by r.category
> GRASS_INFO_END(18452,1)
> ERROR: value <HDD/HyerimYoon/grass/SA1/ProjectHY1/dbf/> out of range for
> parameter <driver>
>       Legal range: mysql,dbf,odbc,sqlite,pg,ogr
> Any help?
Does the full path to ... ProjectHY1/dbf contain white space? If yes,
then this problem should be solved in 6.4.
You could try to download and test v.rast.stats from 6.4.0-release-branch:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
-> see page bottom for file download.
Please report back if that helps.
Markus
