[GRASS-user] Move vertex in v.digit releasebranch
Martin Landa
landa.martin at gmail.com
Fri Dec 26 11:03:31 EST 2008
2008/12/21 Casagrande Luca <thedoktor78 at gmail.com>:
> Hello everybody!
> I am testing the releasebranch with the wxpython interface and I found this
> little problem:
> - open roads from spearfish and start edit it
> - select the move vertex tool
> - after you select a vertex with the left click, if the button is pressed
> again by mistake, the display freeze.
should be fixed in r35035 (relbr64).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
