[GRASS-user] Permission denied (again!)
nikos.alexandris at felis.uni-freiburg.de
Tue Feb 5 07:01:43 EST 2008
Hi!
Thanks for the quick reply. I need it cause we try to
explore GRASS with
a couple of friends and we got stuck on that(!)
First of all:
>grass
Cleaning up temporary files.....
Starting GRASS ...
ERROR: MAPSET PERMANENT - permission denied
Then any other attempt to create a LOCATION ends-up with
exiting GRASS
saying to re-log and find the newly created LOCATION...
which is not
there of course.
I try to edit manually .grassrc6 but still no luck with the
LOCATION
creation.
Thanks.
On Tue, 05 Feb 2008 12:35:39 +0100
Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> sure, you have right permissions on grassdata ?
> what does
> ls -lh /path/to/grassdata/parent/dir
> say?
> jachym
> Nikos Alexandris píše v Út 05. 02. 2008 v 12:17 +0100:
> > Hi list!
> > I shifted from Ubuntu 7.10 32-bit to 64-bit and all of
> a sudden I have a
> > very annoying problem when using GRASS 6.2.2 (from
> Ubuntu repositories)
> > as a simple user:
> > can't create any LOCATION.
> > The same problem on a fresh installed 32-bit Ubuntu (in
> a friends
> > laptop).
> > When I run "sudo grass" I got the access I need.
> > I have given all possible permissions to directories
> and but no luck.
> > How can I once and for all permit simple user to gain
> control over GRASS
> > GIS data base?
> > Thank you,
> > Nikos
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Jachym Cepicky
> e-mail: jachym.cepicky at gmail.com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Nikos Alexandris
Department of Remote Sensing & Landscape Information
Systems
Faculty of Forestry & Environmental Sciences,
Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 /
Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br.,
Germany
