[GRASS-user] MASK seems to be ignored
Patton, Eric
epatton at nrcan.gc.ca
Tue Feb 5 10:59:34 EST 2008
>sure not to do with the problem I had:
>http://www.nabble.com/MASK-does-not-do-it%27s-work-%28-%
>29-with-r.mapcalc-td14407246.html#a14407246
I tried Glynn's method mentioned in that thread, specifically:
r.mapcalc MASK = '!isnull(MAP)'
which worked. Checking the range of the raster I used for a mask in my
r.mask command, it was 0-32767; so shouldn't r.mask in=MAP also create a mask
where any non-null cell in the input raster exists?
Here's the output from r.info for the mask I created using r.mask:
$ r.info MASK
| Layer: MASK Date: Tue Feb 5 11:53:33 2008 |
| Mapset: PERMANENT Login of Creator: epatton |
| DataBase: /home/epatton/Projects |
| Title: Reclass of EC_Charlottetown_Bathy_March_2007_1m_fill_shade_comb |
| Timestamp: none |
| Type of Map: reclass Number of Categories: 1 |
| Data Type: CELL |
| Rows: 999 |
| Columns: 1220 |
| Total Cells: 1218780 |
| Projection: UTM (zone 20) |
| N: 5119638 S: 5118639 Res: 1 |
| E: 491266 W: 490046 Res: 1 |
| Range of data: min = 1 max = 1 |
| Data Source: |
| Reclassified map based on: |
| Map [EC_Charlottetown_Bathy_March_2007_1m_fill_shade_comb] in mapset |
| Data Description: |
| NT] |
| Comments: |
| T] |
| Reclassification of [EC_Charlottetown_Bathy_March_2007_1m_fill_shade_com |
| Category Original categories |
| 1 0-32737 |
~ Eric.
