[GRASS-user] r.contour crashing
Micha Silver micha at arava.co.il
Sat Feb 9 13:27:09 EST 2008
I've not been successful running r.contour on a raster which I made
doing r.patch on a few SRTM tiles. After r.contour runs for a short
while, disk activity goes up, and the progress indicator stops. Then
after another minute, "killed" appears and the contour vector is not
properly created. I tried with a smaller subsection of the raster, and
it succeeded. Here's r.info on the raster that fails:
GRASS 6.2.3 (WGS84):~/geodata/ethiopia > r.info ethiopia_srtm
 | Layer:    ethiopia_srtm                  Date: Sat Feb  9 11:13:04
2008    |
 | Mapset:   PERMANENT                      Login of Creator:
micha           |
WGS84                                                            |
 | DataBase:
/home/micha/geodata/grass                                        |
 | Title:     ( srtm_eth
 | timestamp:
none                                                            |
 |   Type of Map:  raster               Number of Categories:
4517            |
 |   Data Type:
CELL                                                       |
 |   Rows:
14400                                                      |
 |   Columns:
18000                                                      |
 |   Total Cells:
259200000                                                  |
 |        Projection: Latitude-Longitude (zone
0)                             |
 |            N:        15N    S:         3N   Res:
0:00:03                   |
 |            E:        46E    W:        31E   Res:
0:00:03                   |
 |   Range of data:    min = -197  max =
4517                                 |
 |   Data
Source:                                                             |
 |   Data
Description:                                                        |
 |    generated by
r.patch                                                    |
Comments:        |
 |    r.patch input="srtm_eth3,44_12"
output="srtm_eth"                       |
Is the region too large?
Thanks,
Micha
Micha Silver
Arava Development Co, Sapir, Israel
tel: +972(8)6592270
cell: +972(52)3665918
