[GRASS-user] errors in m.proj
Hamish
hamish_b at yahoo.com
Sat Feb 9 20:11:52 EST 2008
Reno Bladergroen wrote:
> The landsat maps i downloaded are in XY-meters projection. I also
> downloaded SRTM-3arc data and those are in LL projection. So when
> i want to import all these data in my location database I get
> errors: projections don't match. I prefer LL projection so
> thought: lets use m.proj to convert all XY data to
> LL projections. When I do this I get the following error:
> Assuming current projection as input, LL WGS84 as output.
> input parameters=[+proj=utm +no_defs +zone=32 +a=6378137
> +rf=298.257223563
> +towgs84=0.000,0.000,0.000 +to_meter=1]
> output parameters=[+proj=longlat +towgs84=0.000,0.000,0.000]
> input file=[/Users/Reno/Documents/Personal files/Zweefvliegen/Scenery
> project/p197r025_7p20000911_z32/p197r025_7t20000911_z32_nn10.tif]
> tr: Illegal byte sequence
> 4d30'40.522"E 0dN 0.000
> Then when I tried to convert the SRTM data to XY-meters, I also got
> the last line error: tr: Illegal etc.
> What did I do wrong?
m.proj is for a list of individual coordinates (like GPS waypoints).
You want r.proj. (pulls map into the current location/mapset, so
import SRTM into UTM location, then in the LL location pull it across
with r.proj)
> Then one more thing: I downloaded finished SRTM data from CGIAR.
> These maps do cover half the continent :confused:, so the region
> is not corresponding to my working region. How can i still use this
> data?
If there is coverage overlap use g.region to set bounds. If you need
data which isn't there you'll have to obtain the next tiles from
another source.
Note a single zone UTM projection is only valid east-west for about
half a continent, at the most, and most SRTM data I have seen was
already in lat/lon. Beyond the 6-degree band you get worse and worse
distortion.
> still waiting for the book...
See Markus's earlier post today.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
