[GRASS-user] problems with topology requested by 2nd vector database
layer
Guido Lorenz
glorenz2000 at yahoo.com
Sun Feb 10 12:11:57 EST 2008
Dear GRASS-users,
I am experiencing some trouble with extracting (and/or displaying) a vector layer, based on a 2nd database connection (GRASS 6.3svn, PostgreSQL 8.26). Viewing the output from v.extract, it can be seen that the table connection is correctly recognised and a sql-selection is performed without errors. Nevertheless, the topology of the new output vector generated indicates that there are any vector elements (see example 1). The same command, but referred to the 1st database table (the original one) gives a correct output vector layer (see example 2).
Both associated tables have the same identifier column (cat), defined as primary key and index column in PostgreSQL. The v.info command shows, that both tables are apparently well connected to the vector layer.
Any ideas about what is going wrong? Thanks for any advice.
Kind regards,
Guido Lorenz
example 1:
v.extract input=vu_transectas_r2 at PERMANENT output=test5 type=point,line,boundary,centroid,area,face layer=2 new=-1 {where=cat > 1} --overwrite
log:
Vector map <test5> already exists and will be overwritten
Load categories from the database (table = geo.test3, db = soils2006).
40 categories loaded from the database
Building topology ...
Registering lines:
0 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Writing attributes...
v.extract input=vu_transectas_r2 at PERMANENT output=test5 type=point,line,boundary,centroid,area,face layer=1 new=-1 {where=cat > 1} --overwrite
log:
Load categories from the database (table = geo.vu_transectas_r2, db = soils2006).
Registering lines:
40 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 40
Number of primitives: 40
Number of points : 40
Number of lines : 0
Number of areas : 0
Number of isles : 0
Layer 1
Done
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
