[GRASS-user] strange behaviour of v.surf.idw
G. Allegri giohappy at gmail.com
Tue Feb 12 05:57:29 EST 2008
Hi Paul. The anomalies are in the raster values, indipendently by the color
table. If you do an r.what around the peak in IDW1 you get raster values
corresponding to the point Z value (about 22000), while if you do r.what on
IDW3 you get values arounf 2000...
2008/2/12, Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> On Tue, 12 Feb 2008, G. Allegri wrote:
> > Hello everyone. In these days I was using IDW to make an easy
> interpolation
> > of a point features layer, and I faced a strange behaviour.
> > My dataset is composed of 122 points, and the attribute to be
> interpolated
> > is Z, in the sample I attach.
> > I've interploated first in a narrow region around a peak. 5/122 points
> were
> > used and the result is this:http://www.geospatial.it/allegri/IDW1.png,
> 491
> > rows x 552 columns of 2 meters cells.
> > Then I've widened the region in the same area:
> > http://www.geospatial.it/allegri/IDW2.png. Ok
> > Then, when I've interpolated across the while area, the result is this
> > strange over-smoothed surface: http://www.geospatial.it/allegri/IDW3.png,
> > where I put in evidence the first small region.
> Are you sure they are really that different? If you could use the same
> colour table for all three images, it would be a lot easier to see. I
> mean, are the values actually very different or are you just going by the
> colours?
> If you still notice anomalies after assigning the same colour table to all
> the maps, I will definitely look into it, as I wrote a lot of the code in
> the current version of v.surf.idw.
> > Another wierd surface I got is:
> http://www.geospatial.it/allegri/IDW4.png ,
> > resulted from a lower resolution setting (50 meters) of the region.
> > About IDW3:
> > Why the interpolation fails to detect local anomalies while it gets
> wider?
> > It seems that the algorithm doesn't manage correctly the incresing
> number of
> > points vs search radius.
> I'm not sure what you mean here. Can you explain further?
> > I will try to take a look at the v.surv.idw code,
> > and to understand what the nrowsxncols/npoints>400 threshold stands
> for...
> It means, if the resolution is quite a lot larger than the number of
> points, it simply searches through all the points for each cell of the
> output raster to find the 12 closest, rather than using a search radius to
> only search those close by. It is just a bit faster. But if you can
> improve the way it detects this it would be very interesting as I'm not
> happy with the choice of such an arbitrary number.
> Paul
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080212/832badf0/attachment.html
