[GRASS-user] Questions: Clipping polygon layer to the outer
boundary of another layer...
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Feb 12 13:49:44 EST 2008
On Tue, 2008-02-12 at 10:21 -0800, Rick Reeves wrote:
> Hello:
> I'm using v.in.ogr to clip a polygon set (in this case, county
> boundaries) to
> the boundary of a (rectangular) raster image.
> As far as I know, this is the only way to do this; I tried to create a
> new location
> with the same boundaries and import the polygon shapefile into the
> location, but
> clipping did not occur as expected.
Sorry for suggesting the obvious things (which you might have checked):
* if you want to clip based on a rectangular, did you try the "spatial"
parameter (or subregion in the GUI)? -- grab the extents of your
rectangular raster with r.info
> In any case, v.in.ogr did not clip the 'boundary polygons' to the the
> edge of the
> raster image, but included the entire polygon. Only excluded polygons
> completely
> outside of the bounding box are clipped.
> There MUST be a way to clip all polygons to the bounding box edge. Can any
> one suggest a way?
> The second edition of Netler's book discusses v.cutregion.sh and
> v.cutter methods,
> but I cant find any evidence of these in GRASS 6.2.
v.cutter is in grass5 -->
http://grass.itc.it/gdp/html_grass5/vector.html
Probably not ported in grass6 -- but it's not really necessary.
> Thanks for any help,
> Rick Reeves
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080212/b67b7999/attachment.bin
