[GRASS-user] v.rast.stats error
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Feb 12 14:35:45 EST 2008
By the way,
some similar problems occur with i.smap (as I have written a few weeks/
months ago). Is there any solution for this?
I understand that @mapset can be very useful but it is a bit scary ;-)
On Tue, 2008-02-12 at 12:31 -0700, Michael Barton wrote:
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> On Feb 12, 2008, at 12:17 PM, grass-user-request at lists.osgeo.org wrote:
> > Date: Tue, 12 Feb 2008 18:20:21 +0100
> > From: Jarek Jasiewicz <jarekj at amu.edu.pl>
> > Subject: [GRASS-user] v.rast.stats error
> > To: grass-user at lists.osgeo.org
> > Message-ID: <47B1D555.9080506 at amu.edu.pl>
> > Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> > Hi
> > When runs v.rast stats with foolowing command:
> > v.rast.stats -e vector=debs at LUBSKO layer=1 raster=depresions at LUBSKO
> > colprefix=dep percentile=90
> > recive error:
> > ERROR:debs at LUBSKO_9432.0 is not in the current mapset (LUBSKO)
> > ERROR:An error occurred while converting vector to raster
> > G__open(r): mapset (LUBSKO) doesn't match xmapset (LUBSKO_9432.0)
> > everything seems clear, but why postfix: _9432.0 after mapset name??
> > Jarek
> I just ran into the same issue today. The script checks to see if the
> map is in the current mapset and is not properly parsing the
> map at mapset format (debs at LUBSKO)
> Delete the @mapset part and rerun this. It should work fine.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080212/85138dee/attachment.bin
