[GRASS-user] V.extrude... confused
Sampson, David dsampson at NRCan.gc.ca
Tue Feb 12 15:57:09 EST 2008
Hey folks.
I want to make a 3d map of canada where each province is extruded base
don certain values.  My provinces shape looked like it was being hassled
so I thought ok, keep it simple.
1. created a small shape in the digitizer
2. v.extrude the vector with a single element
3. used 30 as my height
v.extrude input=Ontario at sampson output=Ontario3D zshift=0 height=30
type=point,line,boundary,area layer=1
And it just hangs (output bellow).
The green bar does not complete.
I am using wingrass 6.3 cvs
And as I'm in windows the v.extrude process is still running. When I
kill the single process the whole GRASS session dies
This is the output:
0 areas built
0 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes     :   19790
Number of primitives:   20075
Number of points    :   0
Number of lines     :   0
Number of boundaries:   0
Building topology ...
Registering lines:    1000   2000   3000
4000   5000   6000   7000   8000
9000  10000  11000  12000  13000
14000  15000  16000  17000  18000
19000  20000
20075 primitives registered
Building areas:
Number of centroids :   0
Number of faces     :   20017
Number of kernels   :   58
Number of areas     :   0
Number of isles     :   0
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080212/fa90907b/attachment.html
