[GRASS-user] v.patch ERROR: Column names differ
Philipp Steigenberger userlist at online.de
Thu Feb 14 14:28:21 EST 2008
Markus Neteler schrieb:
> Craig,
> On Thu, Feb 14, 2008 at 4:04 PM, Craig Leat <Craig at pid.co.za> wrote:
>>  Hi
>>  I tried the following:
>>  v.patch -a -e in=sewer_digit at sewer out=sewer_MN --overwrite
>>  and received:
>>  The columns names don't differ, only the order differs:
>>  v.db.connect -c sewer_MN
>>  TEXT|comment
>>  INTEGER|cat
>>  TEXT|pipe_id
>>  DOUBLE PRECISION|pipe_length_m
>>  DOUBLE PRECISION|pipe_size_mm
>>  and:
>>  v.db.connect -c sewer_digit at sewer
>>  INTEGER|cat
>>  TEXT|comment
>>  TEXT|pipe_id
>>  I'm using 6.3.0RC3, sqlite and sewer_digit is in a different mapset. If I
>>  have to re-order the columns do you have any tips on how to do this?
> Mhh, the column oder will be indeed the problem.
> New columns are added to the right, but that's obviously annoying to
> do manually.
> It should be a general SQL join problem - any experts here?
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
I had a similar problem the other day while renaming columns. As Markus
said its a problem that new columns are added to the right.So its a
little tricky to get the correct order.
To see the current order use
db.select sewer_MN | line
this prints the first line of the table:
comment|cat|pipe_id|pipe_length_m|pipe_size_mm
Now use
v.db.renamecol sewer_MN col=pipe_length_m,pipe_length_m_tmp
and you get
comment|cat|pipe_id|pipe_size_mm|pipe_length_m_tmp
then use
v.db.renamecol sewer_MN col=pipe_length_m_tmp,pipe_length_m
and you get
I also tried to export the file as a .csv with db.out.ogr, to sort it
with awk and to import it again with db.in.ogr -
could be the fastest way, but I couldn't import it again *grmpf* :o/
Got some error-messages like
ERROR: Input DSN <file> not found or not readable
So the rename-thing may be intricately but it works.
cheers
om shantih
Philipp
