[GRASS-user] r.out.gmt -- color palette with gaps?
Dylan Beaudette dylan.beaudette at gmail.com
Wed Feb 20 00:35:49 EST 2008
On Tuesday 19 February 2008 11:00:58 am Carlos "Guâno" Grohmann wrote:
> Hi all.
> I have this color shaded relief map created with r.his and
> r.composite. I want to use it as a base map in GMT, sou I went to the
> AddOns page to get the r.out.gmt script, which creates the color
> palette (.cpt) for me. But when I try to create the map with GMT, I
> get this msg:
> guano at eclipse$ grdimage america_sul_srtm30plus_shade_color.grd -JM15c
> -R-56/-34/-26/0 -Camerica_sul_srtm30plus_shade_color.cpt > amsul.ps
> grdimage: GMT Fatal Error: Color palette table
> america_sul_srtm30plus_shade_color.cpt has gaps - aborts!
> I remember using this script a while ago, and it worked fine..
> thanks for any hint.
> Carlos
Hi Carlos,
I have noticed these type of difficulties involved with CPT files and rasters
with a large (and possible complex) color mapping.
A simple solution I found was to export the red, green, blue channels of your
image (instead of feeding them to r.composite).
Then I use grdimage with the R,G,B grids as inputs:
grdimage $output_raster.red.grd  $output_raster.green.grd
$output_raster.blue.grd ...
Not sure if it would help, but the attached script (not sure how out of sync
with r.out.gmt it is...) may help.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080219/91675b5d/template-0001.bin
