[GRASS-user] Projection of dataset does not appear to match the current location!!!
Kunal Malik kunal.malik81 at gmail.com
Wed Feb 20 02:33:05 EST 2008
HI !!
If i don't know the Projection Information of the File to be Imported,could
i import the raster/vector file available..
 i am Trying to display  one raster image  kept on my harddisk. I have kept
spearfish60 on /usr/local/grassdata
so I set Location . spearfish60
 I have made one user user1 then i set Mapset: user1..
 then i start grass ,,
 the n throu command
 r.in.gdal -e in=nf42.tif out=tm
 then i am getting the error,.,,
 I have tried the same thru GIS manager,,,
 file->import->Raster->multiple formats using gdal..
On 2/15/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> Kunal Malik wrote:
> >  i am Trying to display  one raster image  kept on my harddisk,,
> > I have kept spearfish60 on /usr/local/grassdata so I set Location :
> > spearfish60
> > the n throu command
> > I want to know where i am doing wrong..
> You need to create a location whose projection matches the data you
> wish to import.
> Try using g.proj with the -c flag and the location= and georef=
> options to create a new location based upon the projection information
> in the file.
> You should then be able to import the file into that location with
> r.in.gdal. If desired, you can then re-project it to another location
> with r.proj.
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080220/f230f21b/attachment.html
