[GRASS-user] Projection of dataset does not appear to match
the current location!!!
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Feb 20 04:53:37 EST 2008
Kunal Malik píše v St 20. 02. 2008 v 13:03 +0530:
> HI !!
> If i don't know the Projection Information of the File to be
> Imported,could i import the raster/vector file available..
> i am Trying to display one raster image kept on my harddisk. I have
> kept spearfish60 on /usr/local/grassdata
> so I set Location . spearfish60
why didn't you just create new location ?
> I have made one user user1 then i set Mapset: user1..
could I ask you, how "you did" the user1 ?
> then i start grass ,,
> the n throu command
> r.in.gdal -e in=nf42.tif out=tm
> then i am getting the error,.,,
> Projection of dataset does not appear to match the current
> location!!!
> I have tried the same thru GIS manager,,,
> file->import->Raster->multiple formats using gdal..
if your data are not from spearfish60 region and with the same map
projection, then they should not be imported to the spearfish60
location. you should better create new location with map projection,
that corresponds with the projection of your map.
jachym
> On 2/15/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> harddisk,,
> > I have kept spearfish60 on /usr/local/grassdata so I set
> Location :
> > spearfish60
> > the n throu command
> location!!!
> > I want to know where i am doing wrong..
> You need to create a location whose projection matches the
> data you
> wish to import.
> Try using g.proj with the -c flag and the location= and
> georef=
> options to create a new location based upon the projection
> information
> in the file.
> You should then be able to import the file into that location
> with
> r.in.gdal. If desired, you can then re-project it to another
> location
> with r.proj.
> Thanks & Regards
> Kunal Malik
> 09871147561
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080220/a7b02e00/attachment.bin
