[GRASS-user] automating map production
in Grass
Gerald Nelson
gnelson at uiuc.edu
Wed Feb 20 19:54:11 EST 2008
All grass commands can be run either from the gui or command line. The gui just creates the command and executes it. So you can create a shell script with a text editor that has all your commands, and does the usual things that shell scripts can do and run it from the window that appears when you launch grass.
Jerry
---- Original message ----
>Date: Wed, 20 Feb 2008 18:08:00 -0500
>From: "Alysson Whitlam" <alysson.whitlam at gmail.com>
>Subject: [GRASS-user] automating map production in Grass
>To: grass-user at lists.osgeo.org
> Hi,
> I am just beginning to work with Grass, although I
> am fairly experienced with ArcGIS, including
> scripting for map production and geoprocessing
> (Python and VBA). Basically, I am looking to
> automate map production in Grass, using a script
> (Python or Perl preferably?). (I have to output
> several hundred maps, based on sections of a polygon
> layer). Since I am just beginning to use Grass, I am
> wondering if anyone could please give me an idea if
> this type of task can be accomplished in Grass.
> Thanks very much,
> Alysson
>________________
>_______________________________________________
>grass-user mailing list
>http://lists.osgeo.org/mailman/listinfo/grass-user
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
