[GRASS-user] Problem with display of Raster file.
Kunal Malik
kunal.malik81 at gmail.com
Thu Feb 21 01:39:52 EST 2008
HI!
I am trying to display the tif file ,,
by first importing the tif file by
r.in.gdal -e in=nf42_geo.tif out=tm
WARNING: Datum 'unknown' not recognised by GRASS and no parameters found.
Datum transformation will not be possible using this projection
information.
Projection of input dataset and current location appear to match.
Proceeding with import...
100%
CREATING SUPPORT FILES FOR tm.red
SETTING GREY COLOR TABLE FOR tm.red (8bit, full range)
100%
CREATING SUPPORT FILES FOR tm.green
SETTING GREY COLOR TABLE FOR tm.green (8bit, full range)
100%
CREATING SUPPORT FILES FOR tm.blue
SETTING GREY COLOR TABLE FOR tm.blue (8bit, full range)
r.in.gdal complete.
now i am trying to display the imported file..
i got the error
g.region rast=tm
ERROR: raster map <tm> not found.
when i observe three files are created in PERMANENT/cats
tm.red,tm.blue,tm.green.
but it is not the actual file that i want to see..
Please tell how could i display it.
Thanks in Advance
On 2/21/08, Kunal Malik <kunal.malik81 at gmail.com> wrote:
> Hi!
> Thanks for ur support.
> As u have said ,i got the georefercing information using gdalinfo.
> It give following output
> Driver: GTiff/GeoTIFF
> Size is 5177, 3450
> Coordinate System is:
> GEOGCS[" Unable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value
> Ellipsoid = Modified Everest Datum = Modified Everest",
> DATUM["unknown",
> SPHEROID["unnamed",6377304.063,300.8017000971244]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> Origin = (65.999420352116971,24.000579647883026)
> Pixel Size = (0.001159295766052,-0.001159295766052)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_SOFTWARE=ERDAS IMAGINE
> TIFFTAG_XRESOLUTION=1
> TIFFTAG_YRESOLUTION=1
> TIFFTAG_RESOLUTIONUNIT=1 (unitless)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 65.9994204, 24.0005796) ( 65d59'57.91"E, 24d 0'2.09"N)
> Lower Left ( 65.9994204, 20.0010093) ( 65d59'57.91"E, 20d 0'3.63"N)
> Upper Right ( 72.0010945, 24.0005796) ( 72d 0'3.94"E, 24d 0'2.09"N)
> Lower Right ( 72.0010945, 20.0010093) ( 72d 0'3.94"E, 20d 0'3.63"N)
> Center ( 69.0002574, 22.0007945) ( 69d 0'0.93"E, 22d 0'2.86"N)
> Band 1 Block=64x64 Type=Byte, ColorInterp=Red
> Metadata:
> LAYER_TYPE=athematic
> Band 2 Block=64x64 Type=Byte, ColorInterp=Green
> Metadata:
> Band 3 Block=64x64 Type=Byte, ColorInterp=Blue
> Metadata:
> and then i tried to import the tif file .
> information.
> 100%
> 100%
> 100%
> r.in.gdal complete.
> i got the error
> g.region rast=tm
> Thanks in Advance
> On 2/20/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> > Kunal Malik wrote:
> > > If i don't know the Projection Information of the File to be
> > Imported,could
> > > i import the raster/vector file available..
> > The "Projection of dataset does not appear to match the current
> > location" error can only occur if the file is georeferenced. If it
> > isn't, r.in.gdal will just assume that it matches the projection of
> > the current location.
> > As Frank mentions, you can use gdalinfo to obtain the georeferencing
> > information.
> > And you can use "r.in.gdal location=" or "g.proj -c location=" to
> > create a new location with the correct projection based upon what's in
> > the file.
> > If a file isn't georeferenced and you don't have that information
> > available, you can import the file into an location with an X/Y
> > projection, although you will lose the ability to perform operations
> > which require projection information (e.g. reprojection).
> > More generally, if you have some data but don't know what part of the
> > planet that data refers to, you don't really have any data. It's like
> > knowing that the answer is 42 without knowing what the question is.
> Thanks & Regards
> Kunal Malik
> 09871147561
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080221/e4fd50f0/attachment.html
