[GRASS-user] d.rast.edit does not save edited cells (?)
    Glynn Clements
    glynn at gclements.plus.com
    Fri Feb 22 04:07:48 EST 2008
Nikos Alexandris wrote:
> > However, this only replaces non-null cells. Any null cells result in
> > the corresponding cells in the orignal map remaining untouched.
> > I could fix d.rast.edit to use r.mapcalc instead of r.patch. But it
> > might be better to add an option to r.patch to support this type of
> > usage.
> Would be nice to have that.
> And another question: Is it possible to ad something else besides an
> Aspect map? Use maybe transparencyt and a background command (like with
> r.digit)? What are the limitations?
I'm not sure how a background map could work; it would be obscured by
the map being edited.
The aspect map feature was only added because it was present in the
original d.rast.edit module which the script replaces. I have no idea
what purpose it serves.
