[GRASS-user] Questions: Clipping polygon layer to the
outer boundary of another layer...
Rick Reeves
reeves at nceas.ucsb.edu
Fri Feb 22 11:53:02 EST 2008
Thanks Hamish - This Worked Great.
Hey, while I am writing, can you recommend any GRASS methods for
cleaning line feature
topology, besides v.clean? I am trying to repair a lot of missed
connections in the USGS
NHP2 stream network data so that I can accurately compute stream
distances with v.net.path.
At this point I may be forced to resort to Arc GIS Network Analyst to
diagnose the problems,
but would MUCH rather use the GRASS tools.
A final question: Is anyone aware of a version of the NHP stream dataset
that HAS been
cleaned and repaired to support distance calculations? This would not be
a trivial task,
even for portions of the dataset.
Thanks,
Rick R
Hamish wrote:
> Rick Reeves wrote:
>>>> I'm using v.in.ogr to clip a polygon set (in this case, county
>>>> boundaries) to the boundary of a (rectangular) raster image.
>>>> As far as I know, this is the only way to do this; I tried to
>>>> create a new location with the same boundaries and import the
>>>> polygon shapefile into the location, but clipping did not occur
>>>> as expected.
>>>> In any case, v.in.ogr did not clip the 'boundary polygons' to the
>>>> the edge of the raster image, but included the entire polygon.
>>>> Only excluded polygons completely outside of the bounding box
>>>> are clipped.
> Hamish:
>>> I assume you used 'v.in.ogr spatial='. This works like v.select.
> R:
>>>> There MUST be a way to clip all polygons to the bounding box edge.
>>>> Can any one suggest a way?
> H:
>>> v.in.region + v.overlay.
> Moritz Lennert wrote:
>> Or v.in.region + v.select if you don't wan't to merge attribute
>> tables.
> v.select will act the same way as 'v.in.ogr spatial=' (or a personal
> favourite: 'v.in.ogr -r') which was what the original question was
> hoping to avoid. ie v.select leaves features in or out, while v.overlay
> both allows or omits features AND modifies any features which cross.
> Hamish
> ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080222/143db4c9/reeves.vcf
