[GRASS-user] circular neighborhoods?
Glynn Clements
glynn at gclements.plus.com
Fri Feb 22 21:19:02 EST 2008
Patton, Eric wrote:
> (Aside: the shape can only be modified by using the -c flag *and* using
> a weights file?)
No, the two are mutually exclusive.
If you use neither weights= nor -c, you get a square neighbourhood. If
you use -c, you get a circular neighbourhood. If you use weights=, the
values in the weights file determine the shape of the neighbourhood.
If you use both -c and weights=, you get an error.
