[GRASS-user] Re: wxpython gui: error while loding avevry first layer
Michael Barton
michael.barton at asu.edu
Mon Feb 25 02:18:53 EST 2008
On Feb 24, 2008, at 4:30 PM, grass-user-request at lists.osgeo.org wrote:
> Date: Mon, 25 Feb 2008 00:30:08 +0100
> From: "G. Allegri" <giohappy at gmail.com>
> Subject: [GRASS-user] wxpython gui: error while loding avevry first
> layer
> To: grassuser <grass-user at lists.osgeo.org>
> Message-ID:
> <e12429640802241530j7f95c092l86e5884f94fbb423 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> I'm playing with the new gui. I've tried it yesterday for the first
> time: it rocks!
> There are some warning and little errors the come raised with some
> tasks, but everything seems to work fine.
> The first error I've experimented is:
Can you provide some additional information?
What platform are you using?
What version of GRASS are you using?
> 23:57:44: Can not enumerate files in directory
> '/home/giova/.kde/share/mimelnk/text' (error 13: Permesso negato)
> 23:57:46: Can not enumerate files in directory
> '/home/giova/.local/share/applications' (error 13: Permesso negato)
> It happens when I launch d.vect or d.rast the very first time. I click
> ok and the d.vect (d.rast) window opens correctly. The subsequent
> times I do it, it doesn't happen...
What do you mean by "launch d.vect or d.rast"? Do you mean add a
raster or vector layer to the layer tree? Or are you trying to launch
d.vect from the command line?
> Great work!
Thanks
Michael
> Thanks,
> Giovanni
