[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Mon Feb 25 11:42:08 EST 2008
You're right Michael. Sorry for not being exhaustive.
I'm doing test on Kubuntu 7.10
Grass: 6.3.0 RC5
wxwidgets: 2.8.4.0
python: 2.5.1
TWO ERRORS with vdigit and v.vect.thematic
FIRST ERROR: vdigit
I've loaded (inside the manager) a polygon layer and an empty line
layer to digitize the latter.
Then I've run vdigit from the "tools" menu. I've selected the line
layer as the layer to be digitized.
I get an error window with:
"Unable to initialize display driver, see README file for more information."
Nothing happens... and I loose control on the GUI. I have to kill it
and restart Gra
ss
SECOND ERROR: d.vect.thematic
I create a thematic vector map (from the gui). It's a point layer. I
ask to use graduated_points on a double type attribute.
Execution failed: 'd.vect.thematic map=topsoil_completo at tesi
type=point column=Ece themetype=graduated_points themecalc=interval
size=9 maxsize=25 nint=10 colorscheme=blue-red --q'
GRASS_INFO_ERROR(16631,1): *** You must open a display monitor ***
The same error raises if I launch it from commandline both in wxgrass and tcltk.
Again, I loose control on the GUI and got to kill it.
In Grass tcltk this command works correctly:
d.vect.thematic -s map=topsoil_completo at tesi type=point column=Ece
layer=1 icon=basic/circle size=9 maxsize=25 nint=10
pointcolor=255:0:0 linecolor=0:0:0 startcolor=255:0:0
endcolor=0:0:255 themetype=graduated_points monitor=none
themecalc=interval colorscheme=blue-red
Giovanni
2008/2/25, Michael Barton <michael.barton at asu.edu>:
> On Feb 25, 2008, at 4:14 AM, grass-user-request at lists.osgeo.org wrote:
> > Date: Mon, 25 Feb 2008 01:24:39 +0100
> > From: "G. Allegri" <giohappy at gmail.com>
> > Subject: [GRASS-user] wxpython gui: d.vect.thematic raises error
> > To: grassuser <grass-user at lists.osgeo.org>
> > Message-ID:
> > <e12429640802241624i15de3c42u50c6297de6e35212 at mail.gmail.com>
> > Content-Type: text/plain; charset=ISO-8859-1
> > Another problem with the python GUI.
> > I tried to create a thematic layer with the following command:
> > d.vect.thematic map=topsoil_completo at tesi type=point column=Ece
> > themetype=graduated_points themecalc=interval colorscheme=blue-red --q
> > It raises an wxpython error window with this:
> > "Execution failed: 'd.vect.thematic map=topsoil_completo at tesi
> > colorscheme=blue-red --q' "
> > while in the Grass shell appears the following track:
> > GRASS_INFO_ERROR(26517,1): *** You must open a display monitor ***
> > Sometimes this thematic map appears displayed, but not correctly (just
> > a subset of the points, with the same size), sometimes this exception
> > appear.
> > Is it something with my wxpython again?
> Again, could you please describe the context in which you are running
> this?
> Are you trying to do this from the command line or adding a layer to
> the layer manager?
> If you are adding this to the layer manager, the display should be
> handled automatically. However, if you are trying to run this from
> the command line, you must open an x monitor or specify another
> display driver yourself.
> Also, it would be helpful to know what version you are running, since
> there have been recent updates to both wxPython GUI and to
> d.vect.thematic.
> Overall, you should normally tell us basic information about your
> system, GRASS version, and for the GUI, the context you are running a
> command.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
