[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Mon Feb 25 12:15:39 EST 2008
The strange think is that after having made vdigit, I've run make
install (from the source root), but nothing has been moved to the
$GISBASE/etc/wxpython/vdigit folder.
Anyway I've manually moved grass6_wxvdigit.py but obviously it'not
enough because I can't find _grass6_wxdigit.so. Where should it have
been compiled?
2008/2/25, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2008/2/25, G. Allegri <giohappy at gmail.com>:
> > Martin, I've already compiled vdigit correctly. It didn't give any
> > error or warning...
> If you run 'make' in gui/wxpython/vdigit, you get two files
> 'grass6_wxvdigit.py' and '_grass6_wxvdigit.so'. Maybe you need to run
> 'make install' (depends on your installation procedure) or just copy
> these file to $GISBASE/etc/wxpython/vdigit manually.
> Martin
> > > Hi,
> > > [snip]
> > > > FIRST ERROR: vdigit
> > > > I've loaded (inside the manager) a polygon layer and an empty line
> > > > layer to digitize the latter.
> > > > Then I've run vdigit from the "tools" menu. I've selected the line
> > > > layer as the layer to be digitized.
> > > > I get an error window with:
> > > > "Unable to initialize display driver, see README file for more information."
> > > To make digitizer you need to compile C++ code in gui/wxpython/vdigit,
> > > see gui/wxpython/README for detailed information.
> > > [snip]
> > > Martin
> > > Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
