[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri giohappy at gmail.com
Mon Feb 25 13:17:16 EST 2008
I've solved linking _gdi_.so library into /usr/lib
mmm... not very straigthforward :-)
The second error remains (d.vect.thematic)
2008/2/25, G. Allegri <giohappy at gmail.com>:
> I'm sorry. I had a problem with vdigit compilation and I accidentally ignore it.
>  I had an error with the compiler linker:
>  /usr/bin/ld: cannot find -lgdi
>  collect2: ld returned 1 exit status
>  > The strange think is that after having made vdigit, I've run make
>  >  install (from the source root), but nothing has been moved to the
>  >  $GISBASE/etc/wxpython/vdigit folder.
>  >  Anyway I've manually moved grass6_wxvdigit.py but obviously it'not
>  >  enough because I can't find _grass6_wxdigit.so. Where should it have
>  >  been compiled?
>  >  2008/2/25, Martin Landa <landa.martin at gmail.com>:
>  >  > Hi,
>  >  > > Martin, I've already compiled vdigit correctly. It didn't give any
>  >  >  >  error or warning...
>  >  > If you run 'make' in gui/wxpython/vdigit, you get two files
>  >  >  'grass6_wxvdigit.py' and '_grass6_wxvdigit.so'. Maybe you need to run
>  >  >  'make install' (depends on your installation procedure) or just copy
>  >  >  these file to $GISBASE/etc/wxpython/vdigit manually.
>  >  >  Martin
>  >  >  > > Hi,
>  >  >  >  >  [snip]
>  >  >  >  >  >  FIRST ERROR: vdigit
>  >  >  >  >  >  I've loaded (inside the manager) a polygon layer and an empty line
>  >  >  >  >  >  layer to digitize the latter.
>  >  >  >  >  >  Then I've run vdigit from the "tools" menu. I've selected the line
>  >  >  >  >  >  layer as the layer to be digitized.
>  >  >  >  >  >  I get an error window with:
>  >  >  >  >  >  "Unable to initialize display driver, see README file for more information."
>  >  >  >  > To make digitizer you need to compile C++ code in gui/wxpython/vdigit,
>  >  >  >  >  see gui/wxpython/README for detailed information.
>  >  >  >  >  [snip]
>  >  >  >  >  Martin
>  >  >  >  >  Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
