[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Mon Feb 25 18:37:41 EST 2008
So, I'm on the edge! ;-)
I've seen the snapping tool between layers... The snap happens only at
the end of the digitizing process, but it doesn't appear during it
(the pointer and the node don't appear snapped). Is it something in
development?
Ops, I'm stressing you too much! I'm sorry, I promise I will stop soon :-)
I hope to get into the code enough to bcome helpful in some development...
PS: What about d.vect.thematic. Have you reproduced it?
2008/2/25, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2008/2/25, G. Allegri <giohappy at gmail.com>:
> > I've solved linking _gdi_.so library into /usr/lib
> > mmm... not very straigthforward :-)
> yes, compiling vdigit is quite tricky, it needs to be simplified. The
> problematic is usage of wxPython wxPseudoDC class which is not part of
> wxWidgets itself. Solution would be to use wxDC instead of wxPseudoDC
> in vdigit code. The problem is that in the Python code are used
> methods of wxPseudoDC which are not available in wxDC class, e.g.
> TraslateId() to move objects. Anyway linking against Python extension
> _gdi_.so is not solution, it works on Linux machines, but on Mac
> (AFAIU).
> Congrats, you are one of the few users who manage compile it;-) Enjoy.
> Martin
> > The second error remains (d.vect.thematic)
> > > I'm sorry. I had a problem with vdigit compilation and I accidentally ignore it.
> > > I had an error with the compiler linker:
> > > /usr/bin/ld: cannot find -lgdi
> > > collect2: ld returned 1 exit status
> > > > The strange think is that after having made vdigit, I've run make
> > > > install (from the source root), but nothing has been moved to the
> > > > $GISBASE/etc/wxpython/vdigit folder.
> > > > Anyway I've manually moved grass6_wxvdigit.py but obviously it'not
> > > > enough because I can't find _grass6_wxdigit.so. Where should it have
> > > > been compiled?
> > > > > Hi,
> > > > > > Martin, I've already compiled vdigit correctly. It didn't give any
> > > > > > error or warning...
> > > > > If you run 'make' in gui/wxpython/vdigit, you get two files
> > > > > 'grass6_wxvdigit.py' and '_grass6_wxvdigit.so'. Maybe you need to run
> > > > > 'make install' (depends on your installation procedure) or just copy
> > > > > these file to $GISBASE/etc/wxpython/vdigit manually.
> > > > > Martin
> > > > > > > Hi,
> > > > > > > [snip]
> > > > > > > > FIRST ERROR: vdigit
> > > > > > > > I've loaded (inside the manager) a polygon layer and an empty line
> > > > > > > > layer to digitize the latter.
> > > > > > > > Then I've run vdigit from the "tools" menu. I've selected the line
> > > > > > > > layer as the layer to be digitized.
> > > > > > > > I get an error window with:
> > > > > > > > "Unable to initialize display driver, see README file for more information."
> > > > > > > To make digitizer you need to compile C++ code in gui/wxpython/vdigit,
> > > > > > > see gui/wxpython/README for detailed information.
> > > > > > > [snip]
> > > > > > > Martin
> > > > > > > Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
