[GRASS-user] problem regarding the display of map
Kunal Malik
kunal.malik81 at gmail.com
Tue Feb 26 06:26:53 EST 2008
HI!
i convert the raster map to vector map and the name of new vect map is
map_tf_v
but when i use the display command i am getting following error
g.region vect=map_tf_v
ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
d.vect map=tgr_shp
The bounding box of the map is outside the current region, nothing drawn.
how can i display the map...???
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080226/1d3622a1/attachment.html
