[GRASS-user] problem regarding the display of map
Kunal Malik
kunal.malik81 at gmail.com
Tue Feb 26 07:28:05 EST 2008
I have use this command
GRASS 6.2.3 (spearfish60):~ > r.to.vect
and in the r.to.vect window i have enter the raster map which is converted
into vector format from the raster map present in the spearfish60 database
and the enter the name for the output vector map and the feature line
,after the execution all these i am getting the name of the map in the
vector list .
But when i execute the instruction of display of map i am geetting error.
> ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
> d.vect map=tgr_shp
> The bounding box of the map is outside the current region, nothing
> drawn.
The Platform Used is Red Hat Enterprise Linux.
Grass Version=6-2.3
On 2/26/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Kunal Malik píše v Út 26. 02. 2008 v 16:56 +0530:
> > HI!
> > i convert the raster map to vector map and the name of new vect map is
> > map_tf_v
> > but when i use the display command i am getting following error
> > g.region vect=map_tf_v
> > d.vect map=tgr_shp
> > drawn.
> > how can i display the map...???
> > Thanks & Regards
> could you post the commands, you used, for graster->vector conversion?
> What is your platform? What is your GRASS version?
> jachym
> P.S. Are you sure, you want to send this message to mapserver-users as
> well?
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080226/26ba473b/attachment.html
