[GRASS-user] problem regarding the display of map
Kunal Malik
kunal.malik81 at gmail.com
Tue Feb 26 08:12:02 EST 2008
Hi!
Thanks For ur support .
I will Try it.
I have Taken a sample Code from
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
after compilation of this code ..after making setting in the Make file,
I am getting the Error
ERROR: MAPSET PERMANENT - permission denied
why this error is showing.
it create a directory "OBJ.i686-pc-linux-gnu".containg main.o
HOW COULD I GET THE EXE.
On 2/26/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> hm,
> are you working on raster map's region?
> does v.info say anything?
> try to run r.to.vect in command line (see r.to.vect --help for details)
> and post resulting messages from this module
> jachym
> Kunal Malik píše v Út 26. 02. 2008 v 17:58 +0530:
> > I have use this command
> > GRASS 6.2.3 (spearfish60):~ > r.to.vect
> > and in the r.to.vect window i have enter the raster map which is
> > converted into vector format from the raster map present in the
> > spearfish60 database and the enter the name for the output vector map
> > and the feature line ,after the execution all these i am getting the
> > name of the map in the vector list .
> > But when i execute the instruction of display of map i am geetting
> > error.
> > > ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
> > > d.vect map=tgr_shp
> > > The bounding box of the map is outside the current region, nothing
> > > drawn.
> > The Platform Used is Red Hat Enterprise Linux.
> > Grass Version=6-2.3
> > Kunal Malik píše v Út 26. 02. 2008 v 16:56 +0530:
> > > HI!
> > > i convert the raster map to vector map and the name of new
> > vect map is
> > > map_tf_v
> > > but when i use the display command i am getting following
> > error
> > > g.region vect=map_tf_v
> > > d.vect map=tgr_shp
> > nothing
> > > drawn.
> > > how can i display the map...???
> > > Thanks & Regards
> > could you post the commands, you used, for graster->vector
> > conversion?
> > What is your platform? What is your GRASS version?
> > jachym
> > P.S. Are you sure, you want to send this message to
> > mapserver-users as
> > well?
> > Jachym Cepicky
> > e-mail: jachym.cepicky gmail com
> > URL: http://les-ejk.cz
> > GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080226/16d9035f/attachment.html
