[GRASS-user] MAPSET PERMANENT - permission denied
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Feb 27 02:12:02 EST 2008
so,
since I do not understand, what you are doing, I'll try to describe the
"development procedure" from the beginning:
1) download the source code
2) go to grass_trunk directory
3) download r.example and unpack to grass_trunk/raster directory
4) ./configure ... ; make; sudo make install
5) go to grass_trunk/raster/r.example directory
6) You'll have to adjust MODULE_TOPDIR variable in Makefile to "../.."
7) run make
8) go to grass_trunk
9) run sudo make install
10) start grass
11) r.example should be there (r.example --help is your friend)
BTW: Maybe we should move [rv].example from intevation server to osgeo
as well ?
Where to store it? grass_source/grass-examples ?
Jachym
Kunal Malik píše v St 27. 02. 2008 v 10:51 +0530:
> Hi!!
> I have set the Enviroment Variable by eval 'g.gisenv'
> when i make echo $LOCATION_NAME it gives Map1
> echo $MAPSET GIVES kunal
> echo $GISDBASE =/usr/local/grassdata
> i have following queries
> 1.
> i have copied the r.example dir into
> the /usr/local/grass-6.2.3/raster/ and add the r.example in the Make
> file present in this directory...when i make the directory it still
> giving the message
> ERROR: MAPSET PERMANENT - permission denied
> why is it so when i am using kunal as a mapset.
> 2.
> i want to see the output of r.example which i added ..
> i will run make install after make..my grass is also running ..where
> to go to check the output.
> Please suggest the way to handle the two problems.
> Thanks
> On 2/27/08, Kunal Malik <kunal.malik81 at gmail.com> wrote:
> Thanks Glynn for your support.
> On 2/26/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> Jachym Cepicky wrote:
> > sorry,
> > $GRASSDATA should be the directory, where your GRASS
> data are located
> > $LOCATION_NAME should be name of the location, you
> are using for
> > current GRASS session
> FWIW, the name of the GRASS variable for the database
> directory is
> GISDBASE.
> You can make the GRASS variables appear as shell
> variable with the
> command:
> eval `g.gisenv`
> After which, you can use the variables like e.g.:
> ls -l $GISDBASE/$LOCATION_NAME
> or:
> ls -l $GISDBASE/$LOCATION_NAME/$MAPSET
> etc.
> As for the error message in the subject: you must own
> the mapset
> directory in order to select it as the current mapset.
> The PERMANENT
> mapset will normally be owned by whoever originally
> created the
> location.
> You shouldn't use the PERMANENT mapset as the current
> mapset for daily
> use; create a new mapset instead. PERMANENT should be
> reserved for
> important data which should be readily available
> regardless of the
> current mapset.
> Until you get to the point of needing several mapsets
> in one location,
> you probably shouldn't have anything in the PERMANENT
> mapset except
> for the standard files (DEFAULT_WIND, PROJ_INFO,
> PROJ_UNITS).
> Thanks & Regards
> Kunal Malik
> 09871147561
> Thanks & Regards
> Kunal Malik
> 09871147561
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080227/f4d27a2c/attachment.bin
