[GRASS-user] Help: Completely confused about multi-layered vectors
trying to import TIGER/Line files
Tom Russo
russo at bogodyn.org
Thu Feb 28 10:39:29 EST 2008
I have been trying to wrap my brain around "multi-layered" GRASS vectors and
have only succeeded in wrapping my brain into knots. Perhaps someone here with
a solid understanding of this stuff can help me.
I'm trying to figure out how to import TIGER/Line data and actually get the
attributes of areas pulled in. This is trouble.
The v.in.ogr documentation has an example of how to do it:
v.in.ogr dsn=~/TIGER/BC_TGR layer=CompleteChain,PIP output=t35001_all \
type=boundary,centroid snap=-1
which does indeed import the CompleteChain layer and PIP (Polygon Internal
Point) layers --- it puts the boundaries in layer 1 and the centroids in
layer 2, and if I do a
d.vect t35001_all layer=2
I can see the areas just fine.
Thing is, TIGER data has almost no usable attributes in the PIP layer itself
--- this is nothing more than a centroid with an attribute "POLYID", telling
nothing about the area. To get that information, one needs additional tables
linked to the POLYID field. The TIGER data tries to be a normal form database,
so there are many tables with no geometry that relate back to linking fields
in the attribute tables that are attached to geometry.
There's another table in the TIGER data called "Polygon" that has more
attributes related to the census, such as congressional district and such.
Actual names and types of areas (parks, military installations, etc) are
linked through two tables, AreaLandmarks and Landmarks --- the first links
POLYID to a LAND attribute (an integer) and the second links the LAND
attribute to an actual name --- there is a many-to-one relationship between
AreaLandmarks and Landmarks. The latter table actually contains the feature
class code that tells you what type of landmark the polygon represents. Not
every polygon has a matching record in AreaLandmarks, only those that actually
represent landmarks. The other polygons are just administrative regions or
other artificial areas. On top of that, there appear to be some records of
Landmarks that do NOT have any connection to records in AreaLandmarks -- these
are point landmarks, and so the Landmarks layer of the TIGER data also has
point geometry. Where there is a relationship between Landmarks and
AreaLandmarks I suppose the Landmark point would be usable as a label point.
Attaching the "Polygon" records to the centroids seems an easy problem, as
every centroid has a Polygon record with attributes, and all that's needed
is a table join on the POLYID field between the table already attached to the
centroids and the Polygon table imported with db.in.ogr. I can do that.
The AreaLandmarks are another matter --- only a small fraction of the
polygons have associated AreaLandmarks. For example, in the TIGER/Line data
for Bernalillo County, New Mexico, there are 18597 PIP and Polygon records,
but only 1292 AreaLandmarks records. This makes it seem to me that
AreaLandmarks would be a prime candidate for a third "layer" in the
"t35001_all" vector. My problem is selecting the geometric objects to tie to
the records of the AreaLandmarks table.
I have tried a number of naive things that didn't work. First, I tried to
add a "cat" field to the AreaLandmarks table, then use an SQL UPDATE query
to copy the cat column of the table associated with the PIP records (which
gets called "t35001_all_2" by the v.in.ogr import) that have POLYIDs that
match the ones in the AreaLandmarks:
echo "UPDATE t35001_AreaLandmarks SET cat=(SELECT cat FROM t35001_all_2 WHERE t35001_all_2.POLYID=t35001_AreaLandmarks.POLYID)" | db.execute
and then adding AreaLandmarks as a third database connection. That SQL
update worked fine in the sense that the AreaLandmarks table got the right
cat values out of the layer 2 table, but the approach didn't work, because
as far as I understand it the categories of objects in layer 2 haven't
actually been assigned to geometric objects for layer 3 yet, so linking this
way is meaningless at this step. Attaching the table gives me some warnings,
and apparently attaches no database records to any geometry at all.
So then I tried creating a new reclassified vector with
v.reclass in=t35001_all out=foo col=POLYID layer=2 type=centroid
setting the categories of layer 2 in the new vector to be equal to the POLYID
of layer 2 in the old vector without copying the table, then doing:
echo "UPDATE t35001_AreaLandmarks SET cat=POLYID" | db.execute
and attaching that table to layer 2 of the reclassified vector. This sorta
kinda worked, in that the AreaLandmarks records were attached to features
properly, but left a very large fraction of the features without database
connections. So I could display vector "foo" and use d.what.vect to query
my new attributes, but there were 17305 polygons out of 18597 that I could
click and get a warning of a missing database entry --- I would rather have
only the polygons that have an AreaLandmarks record show up at all when
displaying this layer.
Since I'm rambling now, I'll just cut to the chase and ask my question:
Given a GRASS vector with two attached database tables, one of which (layer
2, attaching attributes to centrois) has a key field POLYID, how can I create
a new layer using a third, much smaller table, that also has a POLYID field,
such that the new layer only contains that subset of centroids where the
third layer table's POLYID matches layer 2's POLYID for that centroid?
At some later point I'll worry about the Landmarks point layer and its
associated attributes, after I've figured out what the story is with
connecting the AreaLandmarks to the subset of centroids.
I am convinced that if I truly understood how layers work in GRASS then my
question's answer would be self-evident, but I also know that "if A then B"
is a true statement when both A and B are false. I have been completely
unable to piece together a thorough (or even marginal) understanding from man
pages and even the third edition "Open Source GIS: A GRASS GIS Approach"
book. Any help anyone can give me would be greatly appreciated.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
