[GRASS-user] Help: Completely confused about multi-layered vectors
trying to import TIGER/Line files
Moritz Lennert
mlennert at club.worldonline.be
Thu Feb 28 12:54:09 EST 2008
On 28/02/08 16:39, Tom Russo wrote:
> I have been trying to wrap my brain around "multi-layered" GRASS vectors and
> have only succeeded in wrapping my brain into knots. Perhaps someone here with
> a solid understanding of this stuff can help me.
> Since I'm rambling now, I'll just cut to the chase and ask my question:
> Given a GRASS vector with two attached database tables, one of which (layer
> 2, attaching attributes to centrois) has a key field POLYID, how can I create
> a new layer using a third, much smaller table, that also has a POLYID field,
> such that the new layer only contains that subset of centroids where the
> third layer table's POLYID matches layer 2's POLYID for that centroid?
I think at this stage your best bet is probably to do something like this:
v.category OldMap option=add layer=3 out=NewMap
#find a link between the category numbers created and the original
# categories, this should work:
v.build OldMap option=cdump > TempFile
# You will have to edit TempFile to only take into account layer 2 and
# then find a way to import the results into your database
v.db.connect -o NewMap layer=3 table=NewTable
#to remove all centroids you do not want:
v.edit tool=delete
or
v.extract
There might be an easier way, though...
I think that you also might want to file a few wishes in the tracker,
such as:
- extend v.category with an option to use a column linked to an existing
layer as the cat for a new layer
- allow v.extract to write the results to another layer of the same file
instead of a different file
- extend v.patch to allow to patch different maps into different layers
of the output map
- create a v.copy.layers to copy elements of one layer to another
Moritz
