[GRASS-user] How to find out an angle between to points on the
map (for r.plane, r.lake)
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Feb 28 17:49:50 EST 2008
On Thursday 28 February 2008, Philipp Steigenberger wrote:
> Hi
> I want to work with r.plane and r.lake to get simulate floodings in DTMs.
> In the section of interest there is a river which runs from about SSW to
> NNE. For r.plane I need the
> azimuth. Is there a tool in GRASS which tells me the angle between two
> points I mark on the map like I can measure in between two points with
> d.measure?
Simple trigonometry is a start. Or on a computer the atan2() function is
useful:
atan2( (end_y - start_y) , (end_x - start_x) ) * 180/pi
will return the angle in degrees. The above example is from R, but the C
implementation should be similar. Check your local documentation.
It shouldn't be hard to add something like this to d.measure for interactive
estimation of bearings.
On a related note, I wrote a module for GRASS sometime ago called d.bearing
which would create a transect from a starting point, a bearing, and a
distance along the resulting line. I will dig the source out and see if it
still compiles. It might be useful to combine that functionality with what
you are talking about.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
