[GRASS-user] Help: Completely confused about multi-layered
vectors trying to import TIGER/Line files
Dave Kindem
dkindem at chartermi.net
Fri Feb 29 09:37:36 EST 2008
If it's helpful, you can also extract attributes to individual .shp
files using ogr2ogr -where. For example
ogr2ogr -where 'cfcc = B11' output.shp input_file.rt1 CompleteChain
(B11 is the TigerLine attribute code for main line railroads)
The individual layers can then be brought into GRASS.
There is a good explanation of this in the book Mapping Hacks (it's
Hack #68).
Dave
On Feb 28, 2008, at 10:57 AM, Dylan Beaudette wrote:
> On Thu, Feb 28, 2008 at 7:39 AM, Tom Russo <russo at bogodyn.org> wrote:
>> I have been trying to wrap my brain around "multi-layered" GRASS
>> vectors and
>> have only succeeded in wrapping my brain into knots. Perhaps
>> someone here with
>> a solid understanding of this stuff can help me.
>> I'm trying to figure out how to import TIGER/Line data and
>> actually get the
>> attributes of areas pulled in. This is trouble.
>> The v.in.ogr documentation has an example of how to do it:
>> v.in.ogr dsn=~/TIGER/BC_TGR layer=CompleteChain,PIP
>> output=t35001_all \
>> type=boundary,centroid snap=-1
>> which does indeed import the CompleteChain layer and PIP (Polygon
>> Internal
>> Point) layers --- it puts the boundaries in layer 1 and the
>> centroids in
>> layer 2, and if I do a
>> d.vect t35001_all layer=2
>> I can see the areas just fine.
>> Thing is, TIGER data has almost no usable attributes in the PIP
>> layer itself
>> --- this is nothing more than a centroid with an attribute
>> "POLYID", telling
>> nothing about the area. To get that information, one needs
>> additional tables
>> linked to the POLYID field. The TIGER data tries to be a normal
>> form database,
>> so there are many tables with no geometry that relate back to
>> linking fields
>> in the attribute tables that are attached to geometry.
>> There's another table in the TIGER data called "Polygon" that has
>> more
>> attributes related to the census, such as congressional district
>> and such.
>> Actual names and types of areas (parks, military installations,
>> etc) are
>> linked through two tables, AreaLandmarks and Landmarks --- the
>> first links
>> POLYID to a LAND attribute (an integer) and the second links the
>> LAND
>> attribute to an actual name --- there is a many-to-one
>> relationship between
>> AreaLandmarks and Landmarks. The latter table actually contains
>> the feature
>> class code that tells you what type of landmark the polygon
>> represents. Not
>> every polygon has a matching record in AreaLandmarks, only those
>> that actually
>> represent landmarks. The other polygons are just administrative
>> regions or
>> other artificial areas. On top of that, there appear to be some
>> records of
>> Landmarks that do NOT have any connection to records in
>> AreaLandmarks -- these
>> are point landmarks, and so the Landmarks layer of the TIGER data
>> also has
>> point geometry. Where there is a relationship between Landmarks and
>> AreaLandmarks I suppose the Landmark point would be usable as a
>> label point.
>> Attaching the "Polygon" records to the centroids seems an easy
>> problem, as
>> every centroid has a Polygon record with attributes, and all
>> that's needed
>> is a table join on the POLYID field between the table already
>> attached to the
>> centroids and the Polygon table imported with db.in.ogr. I can
>> do that.
>> The AreaLandmarks are another matter --- only a small fraction of
>> the
>> polygons have associated AreaLandmarks. For example, in the
>> TIGER/Line data
>> for Bernalillo County, New Mexico, there are 18597 PIP and
>> Polygon records,
>> but only 1292 AreaLandmarks records. This makes it seem to me that
>> AreaLandmarks would be a prime candidate for a third "layer" in the
>> "t35001_all" vector. My problem is selecting the geometric
>> objects to tie to
>> the records of the AreaLandmarks table.
>> I have tried a number of naive things that didn't work. First, I
>> tried to
>> add a "cat" field to the AreaLandmarks table, then use an SQL
>> UPDATE query
>> to copy the cat column of the table associated with the PIP
>> records (which
>> gets called "t35001_all_2" by the v.in.ogr import) that have
>> POLYIDs that
>> match the ones in the AreaLandmarks:
>> echo "UPDATE t35001_AreaLandmarks SET cat=(SELECT cat FROM
>> t35001_all_2 WHERE
>> t35001_all_2.POLYID=t35001_AreaLandmarks.POLYID)" | db.execute
>> and then adding AreaLandmarks as a third database connection.
>> That SQL
>> update worked fine in the sense that the AreaLandmarks table got
>> the right
>> cat values out of the layer 2 table, but the approach didn't
>> work, because
>> as far as I understand it the categories of objects in layer 2
>> haven't
>> actually been assigned to geometric objects for layer 3 yet, so
>> linking this
>> way is meaningless at this step. Attaching the table gives me
>> some warnings,
>> and apparently attaches no database records to any geometry at all.
>> So then I tried creating a new reclassified vector with
>> v.reclass in=t35001_all out=foo col=POLYID layer=2 type=centroid
>> setting the categories of layer 2 in the new vector to be equal
>> to the POLYID
>> of layer 2 in the old vector without copying the table, then doing:
>> echo "UPDATE t35001_AreaLandmarks SET cat=POLYID" | db.execute
>> and attaching that table to layer 2 of the reclassified vector.
>> This sorta
>> kinda worked, in that the AreaLandmarks records were attached to
>> features
>> properly, but left a very large fraction of the features without
>> database
>> connections. So I could display vector "foo" and use d.what.vect
>> to query
>> my new attributes, but there were 17305 polygons out of 18597
>> that I could
>> click and get a warning of a missing database entry --- I would
>> rather have
>> only the polygons that have an AreaLandmarks record show up at
>> all when
>> displaying this layer.
> Hi Tom,
> TIGER data (in its current format) is a beast to work with-- in any
> GIS. I have found that the simplest way to get "normal" looking data
> out of the TIGER files was with the tutorial on processing these data
> using PostGIS [1]. There are excellent instructions on the GeoServer
> page [1] that make use of basic PostGIS functionality, along with some
> self-contained java utilities. Following those instructions I was able
> to get *most* of the point, line, and polygon data (with meaningful
> attributes) extracted to simple tables in PostGIS. It would be a
> simple matter to export to GRASS from there.
> I think that you can get 2000 TIGER data, by county, from our favorite
> 'leading GIS vendor' for free [2]. That format should be simpler to
> use.
> There is also tiger2shp [3] which is now distributed for free
> (Windows).
> Finally, it looks like the US Census will be moving away from the
> current data format, and will be henceforth distributing their data as
> shapefiles [4]. Hurray!
> 1. http://geoserver.org/display/GEOSDOC/Loading+TIGER+data
> 2. http://www.esri.com/data/download/census2000_tigerline/index.html
> 3. http://tnatlas.geog.utk.edu/downloadfree.htm
> 4. http://www.census.gov/geo/www/tiger/future/future_tl.html
>> Since I'm rambling now, I'll just cut to the chase and ask my
>> question:
>> Given a GRASS vector with two attached database tables, one of
>> which (layer
>> 2, attaching attributes to centrois) has a key field POLYID, how
>> can I create
>> a new layer using a third, much smaller table, that also has a
>> POLYID field,
>> such that the new layer only contains that subset of centroids
>> where the
>> third layer table's POLYID matches layer 2's POLYID for that
>> centroid?
>> At some later point I'll worry about the Landmarks point layer
>> and its
>> associated attributes, after I've figured out what the story is with
>> connecting the AreaLandmarks to the subset of centroids.
>> I am convinced that if I truly understood how layers work in
>> GRASS then my
>> question's answer would be self-evident, but I also know that "if
>> A then B"
>> is a true statement when both A and B are false. I have been
>> completely
>> unable to piece together a thorough (or even marginal)
>> understanding from man
>> pages and even the third edition "Open Source GIS: A GRASS GIS
>> Approach"
>> book. Any help anyone can give me would be greatly appreciated.
> I cannot offer any insight into the GRASS vector/layers system right
> now, but there are several good threads from a couple of months ago on
> this very topic (vector/layers/confusion).
> Good luck,
> Dylan
>> Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/
>> ~russo/
>> Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/
>> brain.cgi?DDTNM
>> "And, isn't sanity really just a one-trick pony anyway? I mean
>> all you get is
>> one trick, rational thinking, but when you're good and crazy,
>> oooh, oooh,
>> oooh, the sky is the limit!" --- The Tick
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080229/8c454927/attachment-0001.html
