[GRASS-user] How to find out an angle between to points on the
map (for r.plane, r.lake)
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Feb 29 11:28:49 EST 2008
On Thu, Feb 28, 2008 at 7:26 PM, Hamish <hamish_b at yahoo.com> wrote:
> Dylan Beaudette wrote:
> > > Well of course I had to go and try this out.
> > > attached is a patch (against todays SVN) to optionally print the
> > > bearing between clicks.
> Hi,
> you should add a check so that it won't allow bogus results if the
> location is in Lat/Lon:
> e.g. from d.grid:
> if (geogrid->answer && G_projection() == PROJECTION_LL)
> G_fatal_error(_(".. option is not available for LL projection"));
> (the great circle line's bearing changes with distance along it; unless
> you are interested in the rhumbline?)
> for this stuff also checkout m.cogo, r.transect, r.profile,
> d.rhumbline, d.geodesic
> Hamish
Thanks for the tips. Before I go and make any more modifications /
documentation additions does this small patch appear to be useful
enough to be merged into d.measure ? The m.cogo module is useful
enough, but sometimes an interactive quick approach (such as what
d.measure does) can be extremely useful.
Dylan
