[GRASS-user] Configuring GRASS source code for compilation
under Ubuntu 7.10 -- CFLAGS and LDFLAGS parameters no more necessary
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jan 2 06:06:14 EST 2008
Yes correct.
I did recently a new clean install of almost everything on my machine.
The same with GRASS and I forgot to add the proper rights in
GRASS-source folder and files.
So I was getting an error and I thought trying with sudo will do the
work... which is of course wrong.
Thank you!
On Wed, 2008-01-02 at 11:46 +0100, Moritz Lennert wrote:
> On 02/01/08 10:06, Nikos Alexandris wrote:
> > I just downloaded GRASS with:
> > $ sudo svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
> > I try to compile (under Ubuntu 7.10) as I did in the past with:
> > $ sudo CFLAGS="-g -Wall" LDFLAGS="-s" ./configure --with-cxx
> > --with-freetype=yes --with-ffmpeg=yes --with-postgres=no
> > --with-sqlite=yes --enable-largefile=yes
> > --with-tcltk-includes=/usr/include/tcl8.4
> > --with-freetype-includes=/usr/include/freetype2
> > --with-ffmpeg-includes=/usr/include/ffmpeg
> > --with-opengl-libs=/usr/include/GL --with-readline
> > but I get:
> > "sudo: CFLAGS=-g -Wall: command not found"
> sudo takes the first argument as the command to execute. If you want to
> include several commands (CFLAGS= is one, LDFLAGS= another and configure
> the third), put them into a script file.
> But why do you want to compile as sudo ? This is generally considered
> unsafe. You should only use sudo for 'make install'.
> Or use the debian (and thus Ubuntu) way: dpkg-buildpackage.
> Moritz
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080102/0e66650b/attachment.bin
