[GRASS-user] RE: 3D Streets Data [v.drape]
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Jan 10 14:54:28 EST 2008
On Thursday 10 January 2008, Matthew Pulis wrote:
> Hi again,
> I am really sorry I am sending again but I have tried to read many
> documents on how to use v.drape all gave me the same conclusions I did
> here.
> Is there some extra information you might require that I make available in
> order to get some knowledge on this situation please?
> Also anyone can suggest how I can work out my problem without using v.drape
> please?
> Thanks again J
> Matthew
This is odd behavior indeed. The usage of v.drape is relatively simple, and
the only problem that one might encounter is when the elevation surface does
not extend beyond the extents of the input 2D vector.
Some questions:
1. are you sure that you are working with a vector file which contains lines
(not boundaries) ? If this is the case v.drape will exit with an error- but
will leave an unfinished output vector (I need to fix this!)
2. can you give some examples on how you are invoking the command?
I just gave it a try in the Spearfish dataset
# digit new line:
v.in.ascii --o format=standard out=newline << EOF
VERTI:
L 12 1
594003.22429907 4917469.71962617
594772.28971963 4919333.22429907
596280.8411215 4920102.28971963
598292.24299065 4920545.98130841
599652.89719626 4920338.92523364
600214.90654206 4919717.75700935
601900.93457944 4918978.27102804
602581.26168224 4919214.90654206
603439.06542056 4920753.03738318
603379.90654206 4921581.26168224
603734.85981308 4922675.70093458
604710.98130841 4922646.12149533
1 1
EOF
# convert to 3D
v.drape in=newline out=newline3d rast=elevation.dem
# check:
v.info # looks ok!
# dump for testing:
VERTI:
L 12 1
594003.22429907 4917469.71962617 1454
594772.28971963 4919333.22429907 1580
596280.8411215 4920102.28971963 1490
598292.24299065 4920545.98130841 1373
599652.89719626 4920338.92523364 1439
600214.90654206 4919717.75700935 1457
601900.93457944 4918978.27102804 1328
602581.26168224 4919214.90654206 1345
603439.06542056 4920753.03738318 1266
603379.90654206 4921581.26168224 1221
603734.85981308 4922675.70093458 1182
604710.98130841 4922646.12149533 1198
1 1
The last column is the elevation.
I will look over the source code, and will try and get the bad behavior noted
above fixed. Any devs have some hints on cleaning up if a module fails to
complete?
Cheers,
Dylan
> From: Matthew Pulis [mailto:mpulis at gmail.com]
> Sent: Saturday, January 05, 2008 6:33 PM
> To: 'grass-user at lists.osgeo.org'
> Subject: 3D Streets Data
> Hi,
> First of all Happy New Year to all on the list J
> I am trying to build a 3D Street Network, thus where the streets have
> elevation so I can do routing depending on slope level.
> I am using the GRASS Book Dataset of North Carolina.
> I tried to combine : streets_wake and elev_state_500m layers together,
> using the v.drape :
> v.drape in=streets_wake rast=elev_state_500m method=bilinear out=streets3d
> But to no avail. This is the v.info on streets3d :
> | Number of lines: 49746 Number of islands: 0
> | Number of boundaries: 0 Number of faces: 0
> | Number of centroids: 0 Number of kernels: 0
> | Map is 3D: 1
> | Number of dblinks: 1
> | Projection: Lambert Conformal Conic
> | N: 258102.57210146 S: 196653.34855345
> | E: 676816.24830376 W: 610869.3848495
> | B: 49.16141063 T: 156.87280191
> The result of streets3d ended up exactly as streets_wake without any
> altitude data.
> Any idea how I can do this endeavour please? I am planning the dataset for
> routing using pGRouting afterwards.
> Thanks and regards
> Matthew
> _____
> I am using the free version of SPAMfighter for private users.
> It has removed 19049 spam emails to date.
> Paying users do not have this message in their emails.
> Try SPAMfighter <http://www.spamfighter.com/len> for free now!
> _____
> It has removed 19198 spam emails to date.
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
