[GRASS-user] v.in.ogr fails on dbf with long column names
Craig Leat
craig at pid.co.za
Fri Jan 11 09:39:35 EST 2008
Wow! Lots of advice flooding in. Thanks to all.
v.in.ogr Still fails to import the dbf even if sqlite is my internal
database. I solved the problem by using the cnames option to v.in.ogr.
Regards
Craig
Patton, Eric wrote:
>> there are already several bug reports about problems (bad experiences) with the
>> 10 characters limit in dbf. A simple solution is to use sqlite instead.
>> Regards,
>> Otto
> And even if you aren't an sqlite guru, you just have to install it on your system and use the
> gui-based sqlitebrowser, which provides a handy interface to the most commonly-used database
> functionality:
> http://sqlitebrowser.sourceforge.net/index.html
> ~ Eric.
Daniel Victoria wrote:
> On Jan 11, 2008 10:42 AM, Craig Leat <Craig at pid.co.za> wrote:
>> BTW the dbf is too big (94,000 rows) to load into OpenOffice Calc.
> How about OpenOfice Base? It appears to open dBase files. I don'f have
> a dbf file here to test it but the web page says it does.
> Daniel
Martin Landa wrote:
> from v.in.ogr:
> cnames List of column names to be used instead of original names,
> first is used for category column
> v.in.ogr cnames=cat,col1,col2,...
> could help you?
> Martin
Richard Greenwood wrote:
> dbf field names are limited to 10 characters. ogr2ogr (part of GDAL)
> has a -select clause which would allow you to select only specified
> columns, but might not be able to distinguish between the identical
> column names either.
> Rich
