[GRASS-user] split adjacent categories
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Fri Jan 11 10:25:56 EST 2008
On Thursday 10 January 2008 20:17:24 Patton, Eric wrote:
> >thanks - I added it but the first part:
> >COUNTER = 1
> >already caused
> >COUNTER: command not found
> >can this bash scripting be used in GRASS like that at all?
> >Martin
> Try getting rid of the extra spaces around the assignment statement:
> COUNTER=1
thanks everybody - now it's working:
#!/bin/bash
echo -n "input:"
read input
r.to.vect $input output=tttemp feature=area --o
v.to.rast tttemp output=tttemp_in use=cat --o
g.remove vect=tttemp
max=`r.info -r "tttemp_in" | grep max | cut -f2 -d=`
COUNTER=`r.info -r "tttemp_in" | grep min | cut -f2 -d=`
# while [ $COUNTER -lt $max ]; do
while [ "$COUNTER" -le "$max" ];
do
echo counter ist "$COUNTER"
r.mapcalc "tttemp_1 = if(tttemp_in == "$COUNTER",1,null())"
r.mapcalc "tttemp_inv = if(isnull(tttemp_1),1,null())" >/dev/null 2>&1
r.buffer input=tttemp_inv output=tttemp_buffer distances=100 --o
r.mapcalc "tttemp_area."$COUNTER" =if(isnull(tttemp_buffer),1,null())"
let "COUNTER=COUNTER+1"
done
var1=1
var2=0
# until [ "$var1" -eq "$max" ]
while [ "$var1" -le $max ]
do
echo "$var1" plus "$var2"
r.mapcalc "tttemp_area.0 = tttemp_area.1"
r.patch input=tttemp_area.$var1,p.$var2 output=p."$var1" --o
var1=$(( $var1 + 1 ))
var2=$(( $var2 + 1 ))
done
