[GRASS-user] Intergraph MGGA grid to Grass raster
    Daniel Victoria
    daniel.victoria at gmail.com
    Fri Jan 11 14:38:15 EST 2008
Copy those to your mapset directory, inside the location directory?
I've always found it easier to export everything as GeoTif...
Daniel
On Jan 11, 2008 5:06 PM, Moskovitz, Bob
<Bob.Moskovitz at conservation.ca.gov> wrote:
> Hello list,
> I am using a GIS called MGE which has a module (called MGGA) that can export
> MGGA grids into Grass raster format.  It produces the directories
> cats,cell,cellhd,cellmisc, and  colr.  Anyone know what I do with this?
> Thanks in advance,
> Bob
> Bob Moskovitz
> Seismic Hazard Zonation Project
> California Geological Survey
> http://www.conservation.ca.gov/cgs/shzp
> CONFIDENTIALITY NOTICE: This communication is intended only for the use of
> the individual or entity to which it is addressed. This message contains
> information from the State of California, California Geological Survey,
> which may be privileged, confidential and exempt from disclosure under
> applicable law, including the Electronic Communications Privacy Act. If the
> reader of this communication is not the intended recipient, you are hereby
> notified that any dissemination, distribution, or copying of this
> communication is strictly prohibited.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
