[GRASS-user] Error creating new mapset
Jose A. Ruiz-Arias jararias at ujaen.es
Fri Jan 11 15:13:45 EST 2008
Dear folk,
i have installed GRASS-6.2.3 from source code with no apparent errors during
configuration, compilation and installation. However, when i run grass and
try to create a new mapset i get next error:
g.region: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: Error 40
In fact, when i was setting the projection parameters and chose a UTM
projection, the program did not ask me for the UTM zone, the ellipsoid and
the datum.
In the GRASS configure process I explicitely used the
flag --with-gdal=/usr/local/bin/gdal-config and there were no errors. I
checked for the shared library and it is placed in /usr/local/lib directory.
Before the GRASS installation, I installed the GDAL/OGR bundle from the source
code, with netcdf support, and the GRASS support disabled. Again, there were
no apparent errors. Next I installed the gdal-grass plugin (gdal-grass-1.4.3
with the following options:
configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3)
I did not detect any problem during the installation of these bundles. Anyone
knows about the problem??
Thanks in advance,
José A. Ruiz
