[GRASS-user] Unable to create new project with Grass 6.2.2 in
Ubuntu 7.1
Jan Schorn
js.mailinglists at gmail.com
Sat Jan 12 16:26:05 EST 2008
Hi, list
I installed GRASS 6.2.3 in about 14 computers with i368 architecture and
Ubuntu 7.10 (Les-ejk repositorios). The only way to create a new Location is
using QGIS.
Using GRASS the error explained by Matt occurs.
¿Any ideas?
Thanks,
Jan
2008/1/11, Matt <mlpublic42 at gmail.com>:
> I am unable to create a new location/project in Grass. Since I am new to
> both Linux/Ubuntu and Grass there are a nearly infinite ways to go wrong. I
> have Ubuntu 7.10 installed. I used Synaptic to install Grass 6.2.2 . I
> have been able to start Grass and play with the Spearfish and North Carolina
> datasets. I've made it to page 37 in "Open Source GIS A Grass GIS Approach,
> 3rd ed." As interesting as North Carolina is, I yearn to create a map of
> western New York. But when I try to create a new project closer to home, I
> get nowhere. All the tutorials I've come across treat this as trivial, but
> I'm stuck!
> Starting Grass from the "Run Application" applet ("run in terminal" box
> checked), starts Grass in the terminal window and a Grass Startup GUI window
> appears. Using the Browse button I enter "/home/matt/grass/grassdata" in
> the GIS Data Directory box. The previous created directory map1 appears in
> the project location box and the Accessible Mapsets window is empty. At
> this point I've tried several things. If before starting Grass I put a
> Tiger shp file ( tgr36029lkA.shp) into map1, I'm unable to use it. If I
> click on EPSG codes and select 4326 and click "Define Location" it tells me
> to restart Grass to find the created location. When restarted the location
> is not there.
> Any ideas? Especially how to start a new project using a Tiger shape
> file? (Remember, novice).
> Thanks,
> Matt
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080112/93e942e4/attachment.html
