[GRASS-user] Error creating new mapset
Sun Jan 13 18:34:52 EST 2008
Jose A. Ruiz-Arias wrote:
> i have installed GRASS-6.2.3 from source code with no apparent errors during
> configuration, compilation and installation. However, when i run grass and
> try to create a new mapset i get next error:
> g.region: error while loading shared libraries: libgdal.so.1: cannot open
> shared object file: Error 40
> In fact, when i was setting the projection parameters and chose a UTM
> projection, the program did not ask me for the UTM zone, the ellipsoid and
> the datum.
> In the GRASS configure process I explicitely used the
> flag --with-gdal=/usr/local/bin/gdal-config and there were no errors. I
> checked for the shared library and it is placed in /usr/local/lib directory.
> Before the GRASS installation, I installed the GDAL/OGR bundle from the source
> code, with netcdf support, and the GRASS support disabled. Again, there were
> no apparent errors. Next I installed the gdal-grass plugin (gdal-grass-1.4.3
> with the following options:
> configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3)
> I did not detect any problem during the installation of these bundles. Anyone
> knows about the problem??
Most systems won't load shared libraries from /usr/local/lib without
some additional configuration.
For Linux, you need to either set the LD_LIBRARY_PATH environment
variable to a path which includes /usr/local/lib, or add
/usr/local/lib to /etc/ld.so.conf then run ldconfig (as root).
