[GRASS-user] Importing lines from database
Hamish
hamish_b at yahoo.com
Mon Jan 14 04:01:46 EST 2008
Richard Chirgwin wrote:
> I have a database containing pairs of points, each with lat/long. For
> convenience (there are lots of points) I would like to use this (and
> the distance between the points if necessary) to create a vector map
> containing lines joining the points. This way, I don't have to
> hand-draw a couple of thousand lines.
> I can't see any support in the database import ( v.in.db ) to do this
> - is there some way to create lines directly from my database?
oh, did you want to make a connect-the-dots line (if so how will you
ensure the order?), or did you want lines which connect all points to
all other points?
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
