[GRASS-user] How to calculate the area of a rastermap
opopanax oopopanaxx at yahoo.de
Tue Jan 15 02:16:02 EST 2008
Thank you all,
I wanted to calculate the extent of an area
r.report units=k
is a very nice one and much more better than r.stats
r.surf.area
works as well
 From g.region and r.info I didn't get the information I wanted
Cheers
om shantih
Philipp
_Examples:_
GRASS:~$ r.report wo_08 uni=k
r.stats:  100%
|                         RASTER MAP CATEGORY
REPORT                          |
|LOCATION: wertach_gk_221207                          Tue Jan 15
08:11:22 2008|
|          north: 5367102.02878204    east:
4423032.52391016                  |
|REGION    south: 5262609.45830234    west:
4370953.43615398                  |
|          res:        30.00073801    res:
29.99947451                  |
|MASK:none
|MAP: (untitled) (wo_08 in
x02_landsat)                                       |
|                      Category Information                        |
square  |
|#|description
|kilometers|
|1| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
.|1215.11661|
|*|no data. . . . . . . . . . . . . . . . . . . . . . . . . . . .
.|4226.76114|
|TOTAL
|5441.87775|
GRASS:~$ r.surf.area wo_08
Null value area ignored in calculation 4.226761e+09
Plan area used in calculation: 5.437182e+09
Surface Area Calculation(low, high, avg):
        1.208337e+09 1.208337e+09 1.208337e+09
Current Region plan area: 5.441878e+09
Estimated Region Surface Area: 1.209381e+09
Done.
GRASS:~$ r.info wo_08
 | Layer:    wo_08                          Date: Mon Jan 14 08:04:30
2008    |
 | Mapset:   x02_landsat                    Login of Creator:
om              |
wertach_gk_221207                                                |
 | DataBase:
/home/om/grassdata                                               |
 | Title:     ( wo_08
 | timestamp:
none                                                            |
 |   Type of Map:  raster               Number of Categories:
1               |
 |   Data Type:
CELL                                                       |
 |   Rows:
3483                                                       |
 |   Columns:
1736                                                       |
 |   Total Cells:
6046488                                                    |
 |        Projection: Transverse Mercator (zone
0)                            |
 |            N: 5367102.02878204    S: 5262609.45830234   Res:
30.00073801   |
 |            E: 4423032.52391016    W: 4370953.43615398   Res:
29.99947451   |
 |   Range of data:    min = 1  max =
1                                       |
 |   Data
Source:                                                             |
 |   Data
Description:                                                        |
 |    generated by
r.water.outlet                                             |
GRASS:~$ g.region -p
projection: 99 (Transverse Mercator)
zone:       0
datum:      potsdam
ellipsoid:  bessel
west:       4370953.43615398
east:       4423032.52391016
nsres:      30.00073801
ewres:      29.99947451
rows:       3483
cols:       1736
cells:      6046488
Hamish wrote:
> Philipp Steigenberger wrote:
>>>  I know there is a posibility to calculate the area of a rastermap,
>>> but I cannot find the command.
>>>  I have a water.outlet map. The area data range is 1 to 1
> Carlos wrote:
>> r.surf.area?
>> r.stats?
> 'r.report units=h' too
> Hamish
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080115/78e2ce51/attachment-0001.html
