[GRASS-user] GRASS winver 6.3.svn(2007)
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 16 07:08:27 EST 2008
On 16/01/08 10:53, Malm Paul wrote:
> Hi, it is native.
How come you use d.erase then which is not usable in wingrass (as it is
relevant only for monitors, not the gis.m display ? Could you also
answer the other questions or comments, so that we can find out what the
problem is ?
Moritz
> Kind regards,
> Paul Malm
> -----Original Message-----
> From: Moritz Lennert [mailto:mlennert at club.worldonline.be]
> Sent: den 9 januari 2008 11:44
> To: Malm Paul
> Cc: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] GRASS winver 6.3.svn(2007)
> On 08/01/08 10:05, Malm Paul wrote:
>> Hi,
>> has anyone qot the windows version to work?
>> I'm new to GRASS and I'm not sure if I'm doing this the right way.
>> I'm trying to create contour lines from a DTED file (name=f2227)
>> g.region rast=f2227 -p
>> d.erase
>> d.rast f2227
> Which windows version are you using ? Cygwin or native ? If you can run
> d.mon x0, then this must be Cygwin.
>> r.contour in=f2227 out=elev_c_10m step=10 --o
>> the r.contour program starts but nothing happends!!
> works perfectly in native wingrass
>> I'm also trying to triangulate the dted file:
>> First I tried to create vector points from the dted file
>> r.to.vect input=f2227 output=point1 feature=point -s
>> the program starts but nothing happends!!
> idem
>> Then I succeded to create the point file in Qgis GRASS module
>> after that I draped the pointfile with the elevation file (2D to 3D)
> in
>> Qgis.
>> It created a new point (point3d) file but I can't se if it is in 3D.
> How did you create this file ?
>> but the:
>> v.delaunay input=point3d output=deltriang
> I don't know what point3d is, and am not a triangulation expert, but I
> don't see how the output of r.to.vect is useful for triangulation,
> unless you change resolution before r.to.vect...
>> Craches after a while in Qgis
> Works in native wingrass.
>> in WinGRASS
>> the delaunay function completes (without any succeed- or error
> message).
> How do you launch it ?
>> But when I'm trying to view the layer, I'm getting the following
>> message:
>> "coor files of vector deltriang is larger than it should be (9287051
>> bytes excess)"
>> and
>> "Cannot display areas, topology not availible"
> Try running v.build on the file.
> Moritz
