[GRASS-user] Can't dissolve based on column?
    Patton, Eric
    epatton at nrcan.gc.ca
    Wed Jan 16 15:20:42 EST 2008
Just a clarification...so it's the case that the column parameter in v.dissolve must always be of type integer, and *only* integer?
~ Eric.
-----Original Message-----
From: grass-user-bounces at lists.osgeo.org on behalf of Nikos Alexandris
Sent: Wed 1/16/2008 3:41 PM
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Can't dissolve based on column?
Well... I suspected it had to do with the field type of the column
"CODE_00".
Indeed... the column was "TEXT".
After Daniels (Victoria) indications for a similar problem a change to
"integer" (using sqlitebrowser) solved the problem.
I suggest a clarification about that in the man page of v.dissolved.
Greets...
P.S. Thank you Daniel
On Wed, 2008-01-16 at 16:52 +0100,
nikos.alexandris at felis.uni-freiburg.de wrote:
> All I try to do is a dissolve... and for:
> > v.dissolve input=clc00_clean output=clc00_dissolved
> col=CODE_00
> I get:
> DBMI-SQLite driver error:
> Cannot step:
> SQL logic error or missing database
> ERROR: Cannot fetch data
> ERROR: Unable to open vector map
> <clc00_dissolved_19941 at nik> on topology
>        level 2
> ERROR: Vector map <clc00_dissolved> not found in current
> mapset
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
