[GRASS-user] Can't dissolve based on column?
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Wed Jan 16 15:49:26 EST 2008
For the moment I don't have any other datasets than the CORINE
shapefile(s) tiles and it worked only after this change ("TEXT" to
"integer").
On Wed, 2008-01-16 at 15:20 -0500, Patton, Eric wrote:
> Just a clarification...so it's the case that the column parameter in v.dissolve must always be of type integer, and *only* integer?
> ~ Eric.
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org on behalf of Nikos Alexandris
> Sent: Wed 1/16/2008 3:41 PM
> To: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Can't dissolve based on column?
> Well... I suspected it had to do with the field type of the column
> "CODE_00".
> Indeed... the column was "TEXT".
> After Daniels (Victoria) indications for a similar problem a change to
> "integer" (using sqlitebrowser) solved the problem.
> I suggest a clarification about that in the man page of v.dissolved.
> Greets...
> P.S. Thank you Daniel
> On Wed, 2008-01-16 at 16:52 +0100,
> nikos.alexandris at felis.uni-freiburg.de wrote:
> > All I try to do is a dissolve... and for:
> > > v.dissolve input=clc00_clean output=clc00_dissolved
> > col=CODE_00
> > I get:
> > DBMI-SQLite driver error:
> > Cannot step:
> > SQL logic error or missing database
> > ERROR: Cannot fetch data
> > ERROR: Unable to open vector map
> > <clc00_dissolved_19941 at nik> on topology
> >        level 2
> > ERROR: Vector map <clc00_dissolved> not found in current
> > mapset
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080116/e3b25cec/attachment.bin
