[GRASS-user] Can't dissolve based on column?
Martin Landa landa.martin at gmail.com
Wed Jan 16 16:08:46 EST 2008
2008/1/16, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> My column "CODE_00" was identified as "TEXT", not "varchar". So maybe
> this was the problem (?)
> I merged the tiles outside of GRASS with ogr2ogr -update -append... etc.
> I did not try to merge with v.patch the tiles.
> Is there a difference?
yes, right. It fails when 'text' data-type is used. It should be
fixed. I will try to take a look as soon as possible.
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
